When closing a remote debugging connection, LabVIEW asks if a changed class should be saved. This is nonsense becausenothing can be saved inside the executable. (There also is an error dialog when clicking save. I can save the class in a different place on the local computer, but this does not make any sense.)
This is annoying especially because the dialog is shown for several classes (but not all). Please do not show the dialog in this case.
