6 | |
5 | |
2 | |
2 | |
2 |
Currently if you use the new error constant ring and want to save your VI into a version older than 2012, you get a broken code telling you that this object doesn't exist.
It should be automatically converted to some code as it's already the case for other new functionnalities.
