| User | Kudos |
| 10 | |
| 6 | |
| 5 | |
| 3 | |
| 2 |
When establishing a remote debug connection to an application (Menu Operate->Debug Application or Shared Library...) the control of the remote application is transfered to the debugging computer as well. There is no possibility to control the application from the computer running it. But this is what I often want to do.
Please add a possibility to view only from the debugging computer. (To view the block diagram would be suffucent for me.) I would like if this could be selected while connected (like when connected to a remote panel). When the start mode could be selected in the connection dialog this would be a welcome addition.
