6 | |
5 | |
3 | |
2 | |
2 |
When placing a diagram disable structure, the 'enabled' side of the structure starts blank, and the wirethroughs are replaced with default values. I have never wanted this behavior. Every time, I want it to:
1) duplicate the disabled side to the enabled side
2) select everything in the enabled side except for the wires.
3) execute the 'remove' function I normally get by 'ctrl-space, ctrl-r' (quick drop, remove)
