We all (should) check if an array is empty before passing through a For Loop, if we are indexing it and any references or values pass through the For Loop so that we pass null references or default values for the data type.
Most people use either an "Array Size" primitive for selecting "0" or "Default" or an "Empty Array?" primitive for selecting "True" or "False" in a case structure around the For Loop.
If we could just wire the array to the Case Selector and have it automatically create two cases "Empty" and "Has Data" or something, it will make the diagram cleaner and easier to read, while saving a few second for every instance of use.
