6 | |
6 | |
3 | |
2 | |
2 |
Huge numbers of LabVIEW users are losing their Administrator rights each day because of a continual increase in malware attacks coming from all corners of the globe.
However, many (if not most) programmers at NI still have full Admin rights.
PLEASE be sensitive to this inequality for the sake of your customers' health & sanity!
You guys work hard to provide great support, but huge frustrations and lost time still occur when we try to troubleshoot cryptic error messages that arise because of things like limited access privileges. For example, I was recently informed by NI support that error messages (I had battled all day) related to RT target image retrieval utilities/VIs may be due to file I/O using deeper-than-normal execution threads that require the machine to be in a higher-than-normal level of Admin mode in order to execute...
-sorge
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
