When I open a VI created in LabVIEW 2011 with LabVIEW 2012, I should get a diialog that tell me the VI is being upgradeded. Some codes were written on machine A with only LabVIEW 2011. The codes were modified in another machine with LabVIEW 2012. A lot of extra work was introduced, since the codes need to be converted from 2012 back to 2011.
