8 | |
5 | |
4 | |
3 | |
3 |
When you want to save a XControl, you have to save 5 items ... the savefiledialog appears 5 times ...
The problem is, that when you add an XControl to an autopopulating project, the savefiledialog appears 5 times,
without any memory of the last path used ! You have to browse 5 times save all elements.
Here some possible solutions to this problem ...
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
