If a Facade VI of an XControl registers for some dynamic events (whatever the source), a firing of one of these Events will NOT trigger actual activity (Facade VI activity) within the XControl.
If we register for a static Event (Mouse move on the FP for example) we DO get a trigger for the XControl (Facade VI becomes active).
The unusual situation rises that the Danymic events are registered but not executed UNTIL a static Event is called, after which all of the dynamic events are also dealt with.
Please make it possible for Dynamically registered Events within an XControl to "trigger" the XControl just as static events do.
Shane.
