13 | |
11 | |
3 | |
3 | |
3 |
In the current LabVIEW XML Schema, the flatten to XML string supports variants, but not variant attributes (and by extension waveform attributes as well). This is unfortunate as variant attributes remain one of the best ways of implementing a dictionary type data structure and they are also a useful way of adding additional metadata to waveform signals. In both cases, serializing the attributes to XML strings properly would greatly facilitate data exchange with non LabVIEW code.
Available in LabVIEW 2019 and later.
