8 | |
6 | |
4 | |
3 | |
2 |
When deploying a CAN db, an alias needs to be created to access the database. The writeup is deeply buried in 4-538 of the manual (1200 pages).
An example with a simple switch between the dev & exe should be added to help save time and trouble. Or simply add the functionality to an existing example.
Thank you!
