As the code in block diagram grows, it's better to zoom in to the part of code & work on that.
Also now a days with size of monitors & touch screen being in terms of 19",22",24" & so on, it is very difficult to see the icons, nodes.
The worst case is that the wire becomes so thin that it is difficult to select it.
Refer attachments.
