8 | |
6 | |
4 | |
3 | |
2 |
Many built-in functions have the growable ability. Essentially a function that accepts an array of data in scalar form, this saves the step of building an array prior to wiring a terminal. I would like to select any 1-D array on a connector pane and mark as growable. Then when the vi is used as a subvi, the icon would have the growable ability. This could have been used as for example for making a growable error handler or implementing new compound math functions. I know this is probably hard to do and might be possible with xnodes but I dont have time to learn this. It is useful for making reuasble toolkits which look more like the native G functions
