As we all (should) know we can expand a block diagram by holding ctrl+l-mouse.
How do you solve it when the diagram is too big? Wouldn't it be great it ctrl+alt+l-mouse removed diagram real estate?
Just like with the expand, everything to the right and below gets moved up the size of the marked box, and in case of crossing structures (like a case structure), it should reduce their size the same.
/Y
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Contraction-shortcut-opposite-of-Ctrl-Shift-drag/idi-p...
