5 | |
5 | |
2 | |
2 | |
2 |
I'd find it really helpfull, if there would be a possibility to create a new "value change" case in a event structure by right-clicking the control-terminal in the block diagram. If there is no event structure in that VI, the menu entry ("Create event") should be greyed out or be removed.
