if we want to move a decoration object on the front panel, we can use code similar to this one:
On one hand, this is quite complicated. On the other hand you don't know at this stage, which front panel decoration object you are currently moving (in this case each one).
I think it would be quite helpful, if you could create property nodes for the decoration objects as you would for normal controls or indicators.
