PeterFoerster
creating property nodes for decoration elements with right click.
if we want to move a decoration object on the front panel, we can use code similar to this one:
On one hand, this is quite complicated. On the other hand you don't know at this stage, which front panel decoration object you are currently moving (in this case each one).
I think it would be quite helpful, if you could create property nodes for the decoration objects as you would for normal controls or indicators.
Remember Cunningham's Law
3 Comments
tst
Knight of NI Knight of NI
Knight of NI
This is basically the same as this idea - http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-Explicit-Decoration-References-to-LabVIEW/idi-p/97...
While that idea talks about references and not linked property nodes, the implications are basically the same.
___________________
Try to take over the world!
PeterFoerster
Active Participant
Thanks for the tip.
Sorry that I didn't find this earlier.
JordanG
NI Employee (retired)
