13 | |
11 | |
3 | |
3 | |
2 |
In many software packages, if you do a cut (ctrl+x) then paste (ctrl+v) it will move the item and then sometimes subsequent paste operations will make copies (sometimes they act like the clipboard is empty after a single paste)
In labview it is more like it makes a copy and deletes the original. This is somewhat unexpected behavior for me (maybe others find it normal). I would like to use it to move items around without having to drag somewhere in between (say if I want to move a terminal or local variable from one case to another I have to drag out while braking wire connection change cases and drag back in)
For a control, if it had property nodes, connections in connection pane, events, or local variables all these connections brake or are deleted, and the new item is no longer connected to anything. If you do it on a property node, the new node is un-linked to anything. A local variable is the worst of all in my opinion. It deletes the original local variable but makes a new control that the new local variable is linked to. this seems like it would rarely if ever be desired behavior (you get the same problem just copy/paste on local variable as well). On the other hand just making a new local variable linked to the same control would be great for both cut/paste or copy/paste.
