6 | |
6 | |
3 | |
2 | |
2 |
Quite often, I will see an error message in my log files relating to a built-in, primative VI - for instance TDMS write.
It can be difficult to locate the particular instance of the error if you have many calls to the the same VI on the same diagram.
For normal sub-vis, we can right click and do show all instances. But not for primatives.
This is sub-optimal.
I suggest the current find all instances be extended to support primative VIs
