2 | |
2 | |
2 | |
2 | |
1 |
Another for the wish list.
It would be great if the right-click context menu on a case structure had small glyphs to the left of the text (think similar to the TortoiseSVN context menu for those that know what I am talking about).
The reason behind my request is that it often takes me quite a while (a few seconds really, but it slows me down), to figure out which menu item will duplicate a case and which will delete a case. For some reason my brain interprets duplicate and delete as the same and I always have to think about it.
A simple "+" glyph next to add, a "-" next to delete etc would go a long way to making those menu choices a lot simpler.
See attached pic for an mock up.
There are probably lots of menus that could benefit from something like this.
This idea is currently in the LabVIEW NXG backlog. For LabVIEW 20xx, I'm moving the idea back to the 'New' status to be considered for a future LabVIEW 20xx release.
