| User | Kudos |
| 11 | |
| 10 | |
| 9 | |
| 5 | |
| 4 |
Please make it so that an unconnected bundle is an error. Below is an example of current behavior, where even though the bundle by name is disconnected on the output, it does not cause an error.
