Community Browser
Post an idea
Title says it all. Have a slider or pull-down that increases or decreases the highlight execute rate.
When working with Events, the inability to resize the window for choosing new events and editing existing events is really annoying.
Every single time I need to create a "Value Change" Event, I need to scroll down.  I invested in a 24" monitor so that I wouldn't need to scroll as much.
Please please let us resize this window......
Shane.
With User events we can wire up the dynamic event terminal with null references to essentially switch off the event during run-time.  This is a great piece of functionality which unfortunately is NOT available for "static" Events (defined within the Event structure itself).
I would like very much to be able to set the refnum for a STATIC event to a null reference in order to switch off the STATIC events at run-time, essentially makiing it a Dynamic event.
I know we can link to any object within the VI server hierarchy at run-time and use this to generate dynamic events so why can't we have the extra functionality of USER/Dynamic events for the standard events?
In order to maintain compatibility with existing code, how about adding an additional Terminal to the Event Strucutre "Static Event terminal" which exposes the same functionality as the USER Events for the events defined within the Event strucutre.
Shane.
As soon as we have more complicated data structures (e.g. clusters of arrays), a large portion of the FP real estate is wasted taken up by borders, frames and trims, etc.
We need a palette full of "Amish" 😉 controls, indicators, and containers that eliminate all that extra baggage. We have a few controls already in the classic palette, but this needs to be expanded to include all types of controls, including graphs, containers, etc.
A flat control consists of a plain square and some text (numerical value, string, ring, boolean text, etc). A flat container is a simple borderless container.  A flat graph is a simple line drawing that would look great on a b&w printer. A flat picture ring looks like the image alone.
They have a single area color and a single pixel outline, if both have the same color, the outline does not show. They can also be made transparent, of course. If we look at them in the control editor, there are only very few parts.
Now, why would that be useful?
Let's have a look a the data structure in the image. There is way too much fluff, distracting from the actual data. If we had flat objects, the same could look as the "table" below. Note that this is now the actual array of clusters, no formatting involved! It is fully operational, e.g. I can pick another enum value, uncheck the boolean, or enter data as in the cluster above.
Many years ago in LabVIEW 4, I actually made a borderless cluster container in the control editor and it looked fine, but it was difficult to use because it was nearly impossible the grab the right thing with the mouse at edit time.
The main problem of cours is that the object edges completely overlap, making targeted seletion with the mouse impossible. (For example the upper right corner pixel is the corner of an array, a cluster, another array, and an element at the same time.)
So what we need is a layer selection tool that allows us to pick what we want (similar to tools in graphics editing software). It could look similar to the context help shown in the picture with selection boxes for each line. Picking an object would show the relevant handles so we can intereact with the desired object. Another possibility would be to hover over the corner and hit a certain key to rotate trough all near elements until the right element is selected, showing it's resize handles. I am sure there are other solutions.
As a welcome side effect, redrawing such a FP is relatively cheap.
Message Edited by altenbach on 06-03-2009 09:20 AM
So many times, Darren's history probes have been a great help while debugging my code ! This concept may be enhanced. But at least, these probes should ship with the LabVIEW installer.
Auto-indexing of arrays in for and while loops are a nice luxury in LabView.  One option that could save much time would be a menu option to turn on conditional indexing, this would expose a boolean terminal under the auto-index icon to select if the current itteration should add the itteration to the array or skip it.  From an execution standpoint there would only be a minor performance hit (could still preallocate max array size on for loops and automatically return used subset).  This could also work for autoindexed in but would have less use that the autoindeded out case.  I know I have built many conditional arrays inside of a for loop and it requires a case selection and a build array making the code less readable and requires time and thought.  It can also be less efficient than a compiler can do.
See the example below which would run a for loop and only build array of < 0.1
When you pass a wire from within a case structure to outside a case structure, you have an option of "Use default if unwired".
If we had additionally an option for "Retain Current Value", this would simplify and prevent needless wiring, especially if we are using the state machine pattern. See images below for use case.
Why we should not be able to add shift registers to stacked sequences becuase it will eliminate the break of direction of data flow due to sequence locals.
We should be able to put data to shift register in 1st frame and access it in next frame.Sequence Structure.jpg
Hello everybody,
(as suggested I will separate my idea Expand the functionality of Event structures into four seperate ideas to allow giving kudos separately.)
Make it possible to add conditions to events, e.g. only allow event foo, if condition bar is True. I'm not sure, how this should look like. Some static conditions could be "key pressed == a" coupled with "key down" event. Conditions could also be coupled to controls via registering the control reference like dynamic events. If my idea Expand Event structure functionality: Register new types of references is realized, a condition could also be something like "tcp/ip connection is offline". If a condition is not fullfilled, than either nothing happens or there is a leftside node, which indicates the status of the condition. This should be configurable.
Marc
Hello everybody,
It should be possible to configure events to run first (placing the fired event as the next event to execute like the queue function "Enqueue Element At Opposite End"). Or add priority to events.
Marc
Hello everybody,
Allow for better handling of the event buffer for fired events of Event structures. I would like to have a feature to list and remove item(s) from the buffer of fired events. Otherwise you have always to write some code to catch events, you d'ont want just to execute or you want to remove, because you just pressed the stop button. This could be realised by new leftside and rightside nodes inside the event structure.
Marc
Hello everybody,
Make it possibly to dynamically register references like tcp/ip, visa, queues, etc. for Event structures. Possible events are "new bytes at tcp/ip", "new bytes at seriel port", or "connection closed". In the case of queues it could be the same function as "Dequeue Element" or "Queue referenced closed". There are certainly a lot more of similar references, which could be registered for catching events, which up to now we have to poll regularly or use other event functions (as in the case of visa -> new bytes at seriel port). Benefits are: no more regular polling of changes, better integration of several functions (like using queues to communicate with GUIs instead of dynamic user events), and in my opinion just better code.
Regards
Marc
Hello everybody,
here are my ideas about expanding the functionality of Event structures:
1.) Make it possibly to dynamically register references like tcp/ip, visa, queues, etc. for Event structures. Possible events are "new bytes at tcp/ip", "new bytes at seriel port", or "connection closed". In the case of queues it could be the same function as "Dequeue Element" or "Queue referenced closed". There are certainly a lot more of similar references, which could be registered for catching events, which up to now we have to poll regularly or use other event functions (as in the case of visa -> new bytes at seriel port). Benefits are: no more regular polling of changes, better integration of several functions (like using queues to communicate with GUIs instead of dynamic user events), and in my opinion just better code.
2.) Allow for better handling of the event buffer for fired events of Event structures. I would like to have a feature to list and remove item(s) from the buffer of fired events. Otherwise you have always to write some code to catch events, you d'ont want just to execute or you want to remove, because you just pressed the stop button. This could be realised by new leftside and rightside nodes inside the event structure.
3.) It should be possible to configure events to run first (placing the fired event as the next event to execute like the queue function "Enqueue Element At Opposite End"). Or add priority to events.
4.) Make it possible to add conditions to events, e.g. only allow event foo, if condition bar is True. I'm not sure, how this should look like. Some static conditions could be "key pressed == a" coupled with "key down" event. Conditions could also be coupled to controls via registering the control reference like dynamic events. If my 1st idea is realized, a condition could also be something like "tcp/ip connection is online". If a condition is not fullfilled, than either nothing happens or there is a leftside node, which indicates the status of the condition. This should be configurable.
Marc
If unwired it would default to 0, and at least let thread switching occur.  You could maybe right click on the loop and remove the wait node to make it run as fast as possible (like it is now), but it should be there by default...  Maybe also right-click on it and get to choose between "Wait (ms)" and "Wait until Next ma Multiple"?
(PS: I know that you can do this using timed loops, but I'd like to see it in all of them - I've seen too many "programmers" complain that their CPU is at 100% because their loops are going nuts).
A pop-up that appears when a user hovers over a buffer allocation dot would be very useful.
Data to display:
1) size of allocation in bytes
2) expected longevity (freed when vi quits vs. USR)
3) frequency of allocation (once at first run, each loop, etc.)
I know some of the data can only be a best guess but whatever additional data we can get
will be an improvement, especially when dealing with large data sets.
Thanks.
Matt
