Community Browser
Post an idea
Add support to transparency in picture control. When you load a PNG file to the picture control consider the Alpha Channel instead of a threshold.
I would like the ability to probe the loop iteration terminal ("i" in For and While Loops) without the need to wire it to something (indicator, edge of structure,...).
When we read the "cursor index" property of a cursor from an intensity graph, we only get a single number. This is insufficient and inconsistent.
Since the graph data is a 2D array, we should get an array with two elements, one for the x-index and one for the y-index. Two indices are required to translate the cursor position to the corresponding array element.
(This change would make it more consistent. Have a look at the output of e.g. "array size" and "array min&Max" when the input is a 2D array. Same thing!)
Resizing the front panel so it is correct when running the VI is still very tedious and can easily mess up during editing. The problem is even more severe for Xcontrols, because their runtime size is often very small so there is not even enough room to e.g. display all the tools in the tool bar during editing. Once the runtime size is correctly set, all it needs is a double-click on a terminal that has its FP item hidden outside the visible area and everything on the FP shifts and messes up.
We need three things:
  1. An "edit time" FP size that is "comfortably big" so we can see the entire toolbar and possibly also helper controls and even maybe some comment text intended for the programmer that are outside the operator area and only used for debugging and such.
  2. A "run time" FP size that matches exactly what the operator sees during running.
  3. A special decoration or other visual cue during editing that indicates the FP area that will be visible at runtime.
 We already have the crosshair in the upper left corner when showing the grid, so that could be defined as the upper left corner at runtime by default. All we need is define the upper left and lower right corner and the runtime FP area is uniquely defined. As a visual cue, everything outside the runtime area could be a shade darker or tinted differently than normal to indicate that fact. Running the VI would snap the FP boundaries to the bright area.
Then we also need handles to move any of the boundaries at single pixel increments. A control that scales with the front panel would simply scale to the bright area instead. Of course a legacy mode for older VIs that did not have this feature during their creation needs also to be supported.
The example image shows a reddish transparent area (just to throw out another idea, maybe a slightly darker grey would be better). This is one of my own subVIs that demonstrates the problem at hand. At runtime, only the progress bar should be visible, while at edit time, I want to see all controls, because I might need them e.g. to wire the connectors. It is not easy to switch between the two sizes.
(Of course we can currently program around all that by setting windows parameters via property nodes, but it is ugly, inefficient, and tedious.)
I think it would enhance the usability of XControls if it is possible to define events that an XControl can generate and that can be statically linked to just like other control type-specific events.
Earlier discussions on this topic has been done on LAVA and LAVA.
Ton
Since very early LabVIEW versions, we always had the small sizing tip strip at the bottom that showed the current size in pixels when resizing an object on the front panel or diagram.
This is maybe OK for simple decorations, but for most other objects it is very inadequate and not helpful at all. For example if I resize an "index array" node to show more outputs, the node size in pixels is probably the least interesting information! It would be much more useful to indicate the number of outputs instead.
Now if we resize an "index array" node for 8 outputs, we simply resize until the tip strip shows [8 outputs]. Without this, we need to guess the size, count, resize again, etc. A slow, tedious, and error prone process, especially for larger sizes.
Of course the "resize tip strip" should adapt depending on the object that is being resized to always show the most useful values(s). Here are some possible examples:
Resizing action                      example of tip strip
Resize a 1D array:                  [5 elements visible]
Resize a 2D array:                  [6 rows x 5 columns]
Resize "built array" node:          [7 inputs]
Resize "index array" node:          [5 outputs]
Resize "initialize array" node:     [3 dimensions]
Resize "replace array subset" node: [8 elements/subarrays]
Resize "compound arithmetic" node:  [4 inputs]
Resize a graph:                     [Overall size: 400x600, plot area: 380x500]
It should of course apply equally for front panel and diagram objects. For example the suggestion for the arrays would apply to an array control, array indicator, or array diagram constants.
Of course there are many more possible objects, each with it's on set of useful size parameters. This is just a small collection. Please go over the palettes and make other suggestions!
Message Edited by Support on 06-02-2009 12:36 PM
We always get endless confusion in the forums when looking a code images, because we never know if a string diagram constant in a diagram image is in normal, \-codes, hex, or password display.
I think we could avoid confusion and really enhance code readability if string constants (and possibly string controls and indicators) would indicat their format.
I would suggest something similar to the radix display of numerics.
Here's an example how the same string diagram constant could look like, depending on the selected dispaly format.
