8 | |
6 | |
5 | |
4 | |
4 |
Parallelisation of loops is a great thing in LabView that offers a lot of possibilities and it's very easy to implement. In opposite to this debugging can drive you crazy regularly. A typical situation for me is that there are two loops in parallel whereby the first waits for user input (and handles it) and a second one cycles all the time doing some other stuff.
Assumed that the one with the user event handler needs to be debugged I place a break-point on a good place. When the execution stops there, I usually want to go step by step through the code. The problem is now the 2nd loop: because it is running in parallel the execution pointer jumps always between the two loops. I have to step through each function of both loops even that I only interested in the first one.
This becomes very annoying, confusing and time consuming if there is a lot of code in the 2nd loop, if the diagram becomes larger at all and if the highlight mode is activated.
To avoid this I suggest to show optional elements for debugging for each loop. With those elements I could decide if I only want to step through the code of the first loop while the second is executed normally (no highlighting, no single step).
Current situation:
improved functionality:
