| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
I just want to have a layer manager additionally to set a frontpanel element to a specified layer. Using Ctrl+J or Ctrl+K (Ctrl+Shift+J, Ctrl+Shift+K) is only relative to other frontpanel elements.
So if i move a group of elements between other (locked) elements i couldn't define which layer i want to use.
I also would like to have a property for layer level (property node and item in the property dialog).
