okubik
<Ctrl> + click for wiring Case Selector Terminal
LV currently allows you to swap wire positions (on BD) or terminals on the connector pane just by clicking on connection point while holding Ctrl key.
So why to not implement this also for the Case Selector Terminal?
Then you would be able to wire Case Selector Terminal in two clicks:
Of course swapping cursor will only appear if you select terminal that is considered as compatible/valid input of the Case Selector Terminal (based on auto-proofing which will exclude arrays clusters images, references and so on).
CLA, CTA, CLED
3 Comments
crossrulz
Knight of NI
I like this implementation better.  And it was completed in 2015.
Make Case Selector
okubik
Active Participant
I agree. Moreover it's consistent with the way how it works with terminals at connector pane. With no need for additional item under the right click menu items which seems to be obsolete.
CLA, CTA, CLED
Darren
Proven Zealot
Status changed to: Duplicate
