6 | |
6 | |
3 | |
2 | |
2 |
Very often there is the situation that I have to insert an illustrating drawing my front panels. Most of the time I have the problem, that those graphics does not have a transparent background. It would be great if the Coloring tool could be used to change the colors of the bitmap to transparent but also to other colors. If you integrate such a function please also think about a local / global option in the color dialog.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
