I would like to make sub-vi's that look like the following:
Resistor arrays can come in multiple forms, and each form has a purpose.
<---- Resistor Array SIPP
<---- Resistor Array SOIC
There is a time and a place for each.
The VI "desktop" is at a premium for larger or more complex systems. Being able to reduce the "ink" to what is absolutely necessary can have good value. I wish that the icons could be made to be "text plus pins" without requiring artwork.
