6 | |
5 | |
3 | |
3 | |
2 |
Compare the upper loop(old) with the lower loop(new).
Take a close look at the loop exit.
Solution: Right click the indexing tunnel and select "Enable Conditional Append"
This works not only with FOR-Loops.
History: This idea was already presented by me in May 2008 http://lavag.org/topic/7574-conditional-append/page__p__44719&#entry44719
