3 | |
2 | |
2 | |
2 | |
2 |
Discussed here: http://lavag.org/topic/9570-new-wire-type-the-null-wire/
Summary: a right click menu option "Visible Items -> Sequence Container" on all VIs, prims, etc (almost anything on the diagram) to allow us to wire force flow control, without having to wire into/out of the actual node.
