crelf
"Sequence Containers" to force execution flow without data dependancies
Status: New
Discussed here: http://lavag.org/topic/9570-new-wire-type-the-null-wire/
Summary: a right click menu option "Visible Items -> Sequence Container" on all VIs, prims, etc (almost anything on the diagram) to allow us to wire force flow control, without having to wire into/out of the actual node.
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
20 Comments
tst
Knight of NI Knight of NI
Knight of NI
> eg: the "add" primative - if the wires to it aren't broken, then there's no way for there to be an error in there
It's interesting you should mention the Add primitive. Try wiring a waveform into it and see what happens.
___________________
Try to take over the world!
donkdonk
@crelf,
>"adding error clusters to elements that don't need them will added the overhead required to handle them"
You may be right, I just simply would't know. I'd guess if the error cluster is simply there for sequence purposes, a compiler would know and cause no overhead.
>"then there's no way for there to be an error in there". So what?
>"Besides, retro-fitting all subVIs and primatives with error clusters is not only a lot of work [....]
You probably are right, but I would not suggest to fit all primitives. I've never felt the urge to have an additional way of forcing a sequence after a 'add primitive' apart from the scalar wire resulting from it.
An example BTW is the "time delay" express vi which I now use often instead of the 'wait (ms)' primitive. That's what I had in mind when I put my reply.
I agree however, that your suggestion is much more flexible. But as it is presented now, it too much suggest there's dataflow.
>[..], it'll creak a *lot* of code and will make saving VIs for previous versions a nightmare".
Didn't think of that, good point, I guess.
donkdonk
@crelf,
>"and there will be primatives and subVIs that don't need error clusters"
yes, probably lots of them. But then, so what?
>"fitting all subVIs and primatives with error clusters is not only a lot of work [..]"
Probably, but then I would not suggest to provide every primitive with error clusters.
In fact, when I replied to your idea, I was thinking about the 'time delay'express vi I now use a lot more than the 'wait ms' primitive.
>"elements that don't need them will added the overhead required to handle them"
I'm not an expert, but I'd guess that a compiler easily 'knows' the difference between serious error handling and just sequence handling.
>"[..]will make saving VIs for previous versions a nightmare".
Yes, probably a good point mentioning this.
The idea you have probably is the most flexible and also easy to implement, but as said before, I feel strongly uncomfortable with connections that look like data carriers, but aren't. Especially to new users, it must be a nightmare.
However, someone might have a good idea that make the "sequence connections" look very different from data wires. As a start, I suggest to use arrows (or a line with an arrow every 20 pixels or so) for this purpose.
donkdonk
@crelf,
donkdonk
@crelf,
donkdonk
@crelf,
donkdonk
@crelf,
Or just right click, and an additional node is attached to the primitive..
donkdonk
@crelf,
Or just right click, and an additional node is attached to the primitive.. See attached figure.
donkdonk
ahh,
All my posts are here.....I didn't see them. One has to click on top of the page to see the next 10 replies...
Thanks to subscriber ' tst' this all comes to an end now 😉
Sorry for the duplicates...
rgvdh@rdf
I understand that sequence structures are frequently overused and misused, but isn't coordinating tasks that don't really share data but still need to be sequenced exactly what it's for?
