6 | |
2 | |
2 | |
2 | |
1 |
A 3-numeric cluster will be interpreted as "start - step - stop" if connected to a for loop:
The feature can be enabled or not, like "indexing" on arrays.
The structure will be changeable to an array by accessing the popup menu:
The result, of course, will be:
