11 | |
8 | |
3 | |
3 | |
2 |
When you use the "View cluster as icon", the icon which replace the cluster is created automatically depending on the types included.
But when you create a control/type def, stric type def, you have the ability to define your own icon.
So it should be nice to replace the "automatically created icon" by the user defined one.
This icon could be, a little bit, visualy modified in order to differentiate VI's icon and cluster icons. (Something like an additionnal border ???)
Manu.
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
