6 | |
5 | |
3 | |
2 | |
2 |
Background:
I have a single pane that I was using to debug a state machine. It is not clever at all, but it is useful.
I viewer of the Snip might not see what I did here, but I used the "Align Objects >> Left Edges" tool and the "Distribut Objects >> Vertical Compress" tool to get all the text tags and the order of the components to be "human readable".
A human doesn't know that but the software should.
When I hit "cleanup" I get this:
From this image you can observe that "fast, human readability" is lost. I can hunt, but its not a simple up-down.
I think that the "cleanup" should recognize the formmating, and retain it in this case. It should do this by default. The entire paradigm of LabVIEW is visual programming. The diagram cleanup tool, in this particular case, has room for improvement there.
