When comparing a U32 with an I32, e.g. with Less?, it will compare U32's. The result is that an I32 of -1 is considered larger than a U32 of 2. Of course converting the U32 to an I32 would solve this problem. My idea is that LabVIEW allows me to choose the coersion type on the Less? function (and the likes).
