We know there are lot of posts in Version Conversion Board for conversion of VIs and DLLs from one version to the other.In other programing languages like .net we can see the 'VERSION CONVERSION WIZARD'.Using that we can easily convert from one version to the other.Why there is no such conversion wizards in labview?It will be very helpful.Is there any problems for creating a conversion Wizard?
I strongly forwarding the idea of a version conversion wizard.
