| User | Kudos |
| 13 | |
| 11 | |
| 6 | |
| 6 | |
| 4 |
Problem:
I faced to delete multiple elements form the array which is having 20 steps.
solution:
if able to select multiple elements by holding the shift key we can delete selected items 1 time and can insert 1 time.
