10 | |
3 | |
2 | |
2 | |
2 |
I very much like the formula parse and evaluate vi's. For me writing a formula is easier and I am making less mistakes writing formulas than wiring numeric nodes. Specially when the formula is taken from literature.
Unfortunately, the parsed formula is much slower than using standard numeric nodes. Browsing through the formula nodes, I notice that the formulas are parsed down to the same standard numeric nodes (add subtract etc.). Still the formula parsing method is much slower because of many case statements that have to be executed before arriving at the level of the numeric building blocks.
I think from the status where the formula parsing blocks are now, it would be feasible to have the formula parsing blocks generate vi's using only numeric nodes so the formula parsing nodes will have the same performance as the standard labview mathematics. The best solution would be to include it in the building/compiling of the code.
Arjan
Declined for reasons listed here: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/speed-up-formula-parsing-by-scripting-compiling-the-fo...
