6 | |
5 | |
2 | |
2 | |
2 |
I like very much the possibility to cycle between "wire" and "select" by pressing the space bar, when editing the block diagram. But usually, I need to edit string or path constants: so I'd like to select the "text edit" tool if I press the space bar again.
The same should apply to front panel editing: cycle should be:"operat value (finger)", "select (arrow)", and text. That's useful to edit labels.
I don't like using the "auto selection tool" when editing BDs or FPs, because you need to be very accurate when pointing the mouse.
