xdaf
space bar should cycle also "text edit" when editing
Status: Declined
This feature already exists in LabVIEW
I like very much the possibility to cycle between "wire" and "select" by pressing the space bar, when editing the block diagram. But usually, I need to edit string or path constants: so I'd like to select the "text edit" tool if I press the space bar again.
The same should apply to front panel editing: cycle should be:"operat value (finger)", "select (arrow)", and text. That's useful to edit labels.
I don't like using the "auto selection tool" when editing BDs or FPs, because you need to be very accurate when pointing the mouse.
4 Comments
G-Money
NI Employee (retired)
This is already in LabVIEW. If you turn AutoSelection off (Shift+Right Click and then turn off the green button) then you can use Tab to switch between the different tools. Autoselection has gotten a lot faster and smarter since 6.1 so I tend to leave it on.
G-Money
Status changed to: Completed
xdaf
Active Participant
Thanks to both for your suggestions.
Regards
G-Money
Status changed to: Declined
