be able to swap inputs even if one of both is unwired!
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Enable-connection-swapping-even-if-only-one-terminal-i...
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Use-the-wiring-tool-to-swap-inputs-or-outputs-which-ha...
duplicate ... ok (sorry)
