6 | |
5 | |
2 | |
2 | |
2 |
labview needs a primitive that makes it easy to modify a path into another slightly different path. my main need is to be able to change the file extension (or append one), but i also find myself moving a file to another relative location nearby (and changing the file extension). this requires many different operations today (even with the new 'get file extension' palette item). let's go all the way and make something truly useful.
