| User | Kudos |
| 12 | |
| 10 | |
| 6 | |
| 4 | |
| 4 |
If you have a custom control or vi that you would like to access on your pallete, you need to save it into a folder called user.lib on your local drive. If you have a team of developers and you would like them to have the same set of tools in their user.lib, it would be difficult, since the user.lib is maintained individually on their individual harddrives.
It will be great if I can place a shortcut instead of a hardcopy of my custom vi into the user.lib. The shortcut will point to a source control location, possibly a network drive. Since it is no longer a hardcopy in the local user.lib folder but a shortcut, if a custom vi is updated, the shortcut will direct you to the latest copy.
It will be so much better if I can tell LabVIEW where my custom vi or controls are, instead of having to save them in user.lib only. The option will give much flexibility.
Yik
