LabVIEW Interface for Arduino Discussions
ADS1115 Labview Interface for Arduino
pls kindly help upload the VI
Message 11 of 32
(9,665 Views)
this the all configuration off them
Message 13 of 32
(9,463 Views)
how can I use your VI to read 2 differential inputs?
Thanks!
Message 14 of 32
(9,229 Views)
here is the VI that  you can use
remember this is the all configuration. You only need to send the bits
note i edit the mesage
please not use this VI its have a problem with the bolean convertion please use a VI thats i post later
Message 15 of 32
(9,222 Views)
always remember that when you use a arduino to read or write sometime you have to install a time delay in your VI because  if you send a  comand to read the arduino need time to process the comand and if you send a new read comand the arduino dont have time to finish the firts comand normali i use a 5mS time delay
I detect it when I try to read two analog input of arduino. I only recive noise but when i instal a time delay I fix the problem
Message 16 of 32
(9,220 Views)
this vi is functional i chek it last VI i upload is wrong theris a problem with the bolean convertion
Message 17 of 32
(9,190 Views)
thanks for your help!
I tried your VI with the LINX toolkit but I always get this error:
Message 18 of 32
(9,176 Views)
tonight y will check your VI but i see that you use I2C address =48 and the ADS works with only this address
address pin conected to                                            address selected
gnd        72
vdd        73
sda        74
scl        75
remenber you only can select this 4 address
try to conect the address pint to gnd and use the addres 71 instead 48
i will ched your vi tonight
omar
Message 19 of 32
(9,151 Views)
thats  right i check you VI with the address 72 and its works remember to use the address 72 you have to connect the address pin to GND
i use a arduino mega buts is the same
i edit the answer  i use 72 in decimal thats the same 48 in exadecimal
 72 decimal is the same x48
you can fix the problem using 72 in decimal or use 48 in exa(x48)
omar
Message 20 of 32
(9,169 Views)
