LabVIEW Interface for Arduino Discussions
Bad Sync Packet Using UNO
Greetings Fellow wizards.
Connecting with an arduino Uno for the first time, and I can't get past the INIT VI. Looking at highlighted execution I see that it is stuck here:
Bad Sync Packet where it sits. The tx/rx LEDs are Flashing when I attempt this, and not when I don't. The UNO is functional. I've tried examples provided, and they do the same thing. I can't find anything online that helps. I've also attached the VI I'm working with . Thank you everyone in advance!
SPEAKS
(5,830 Views)
Accepted by Speaks
Spoiler
I was hoping for some responses, But I think I found the solution: I have to install LIFA_Base.ino to the Arduino. My concern is that there has not been any updates for Arduino for some time, and I'm wondering if there is other more up-to-date vi's available for this application? I can't seem to find any.
Any advice?
(5,760 Views)
Accepted by Speaks
LIFA hasn't been updated for several years because it was replaced by LINX a couple years ago.
(5,688 Views)
Thanks Nathan. I figured that out a while ago, but continued with LIFA anyway. Its working.
(5,681 Views)
