LabVIEW Interface for Arduino Discussions
Error compiling LIFA_Base.ino for Labview 2012
I had the  same error :
LIFA_Base.cpp.p: In function 'loop':
C:\Program Files (×86)/LIFA_Base.ino.......
Pls can u explain what all files should be opened in arduino.
All the files open except keywords, IRemote license and a folder named LabVIEWInterface.
I even tried adding  LabVIEWInterface sketch . So I had LIFA_Base,AF Motor,AF Motor.h, AccelStepper.cpp,AccelStepper.h,IRemote.cpp, IRemote.h, LabVIEWInterface.
After compiling this I got:
LabVIEWInterface. Ino:In function ' int checkForCommand()':
LabVIEWInterface:97:'bufferBytes' was not declared in this scope.
I also wanted to know that you had mentioned about temporarily removing AccelStepper.h. did u refer to  removing it from LIFA_base or arduino software files . In arduino files I couldn't find that and in LIFA_BASE it doesn't work for me.
regards.
Message 11 of 40
(3,767 Views)
hello sir,
i want to use  LIFA_BASE and upload it in my arduino but i am getting
some compiling errors .
LabVIEWInterface.
Awaiting your reply in anticipation.
Message 12 of 40
(3,767 Views)
I'm new to experimenting on arduino. I get an error as follows.
C:\Program Files (x86)\Arduino\libraries\RobotIRremote\IRremoteTools.cpp:5: error: 'TKD2' was not declared in this scope
Any ideas?
Kind regards
Dany
Message 13 of 40
(3,767 Views)
That is a common error (there are several discussions about it).  I think it might be the wrong Arduino IDE version or something.  Make sure that you have version 1.0.5.
Message 14 of 40
(3,767 Views)
Excellent. Worked for me!:)
Message 15 of 40
(3,767 Views)
Hi Nathan,
Thanks for the response. It worked for me.
Is there a way to make the arduino run on its own without being connected to a computer running LV?
Kind regards
Dany.
Message 16 of 40
(3,767 Views)
You cannot run LabVIEW code on an Arduino.  That's not the literal answer to your question but if that answers it then that's great.  Otherwise, what exactly are you trying to do?
Message 17 of 40
(3,767 Views)
I am trying to control the speed of 4 motors based on some specific feedbackfrom a gyroscope. I understand I can accomplish this using some labview code, but I was wondering if there was a way to make the arduino run and accomplish this independently on its own.
Message 18 of 40
(3,767 Views)
Of course, that's is one of the many uses of an Arduino. You'll just need to write the entire code on the Arduino. There are many online resources for the Arduino that you can use to help you out.
All of my interaction with Arduino has been in the context of using LabVIEW.
Message 19 of 40
(3,767 Views)
voy a probar el 1.0.5 a ver q pasa por q con el 1.0.6 no me deja sale un error
Message 20 of 40
(3,767 Views)
