LabVIEW Interface for Arduino Discussions
Error compiling LIFA_Base.ino for Labview 2012
Yes you must use LINX ,LIFA was not longer supported, check in here
https://www.labviewmakerhub.com/doku.php?id=learn:tutorials:libraries:linx:getting_started
hope it help.
Message 31 of 40
(4,428 Views)
hello,I met these problem,how should I do?
Arduino:1.6.3 (Windows 7), 板:"Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
LabVIEWInterface.ino:17:67: fatal error: OneWire.h: No such file or directory
compilation terminated.
Multiple libraries were found for "IRremoteInt.h"
Used: F:\Arduino\libraries\RobotIRremote
Not used: F:\Arduino\libraries\LIFA_Base
编译有误。
  报告将会包含更多的信息
  "在编译时,输出详细信息"
  在 文件>首选项 中启用
Message 32 of 40
(4,428 Views)
You should upgrade to LINX (http://www.labviewmakerhub.com).
Message 33 of 40
(4,428 Views)
I am the beginner, I don't know how to do, may you tell me detailedly?
Message 34 of 40
(4,428 Views)
I tried it again and and again but i never succeed but i don't want to give up...
but i feel very tired
Message 35 of 40
(4,428 Views)
There are tutorials available for how to install and set up LINX. One is a
video for the Sparkfun kit but the procedure is essentially the same.
Message 36 of 40
(4,428 Views)
QQ截图20150909010849.pngcan you tell me what happen?
Message 37 of 40
(4,428 Views)
Message 38 of 40
(4,428 Views)
Hey,
LIFA has been replaced with LINX.  LINX provides all of the same features as LIFA and many more.  One of the major improvments that LINX makes is that you no longer need to build the firmware from source code so you won't get errors like your post above.
Check out LINX here and let us know if you have any questions in the LINX forums and we'll help you get everything working.
Thanks!
-Sam K
LIFA and LINX developer.
Message 39 of 40
(4,428 Views)
QQ截图20150909010849.pngwhat's the error?
Message 40 of 40
(4,428 Views)
