LabVIEW Interface for Arduino Discussions
Hardware in the loop simulation with Arduino
Hello and thank you for your attention.
I have a transfer function in labview and i want to design a PI controller for that, in Arduino.I used VISA to connect labview to Arduino. i attached my VI and  this is my arduino code:
#include <PID_v1.h>
double Setpoint, Input, Output;
double Kp = 36, Ki = 19, Kd = 0;
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
void setup()
  Serial.begin(115200);
  while (!Serial) {}
  Setpoint = 30;
  myPID.SetMode(AUTOMATIC);
int bytesToRead = 0;
char msg[64];
void loop()
  if (Serial.available())
    getMessage();
    float feedback = atof (msg);
    Input = (double) feedback;
    myPID.Compute();
    Serial.println (Output);
void getMessage()
  int i;
  bytesToRead = Serial.available();
  for (i = 0; i < bytesToRead; i++)
    msg[i] = (Serial.read());
  msg[i] = '\0';
the Set point is 30 and the output of the transfer function should be 30 but it stop on 25 and when i change the Kp and Ki and set point nothing change and the output of transfer function is 25...
So what is the problem??
I realy need this....thanx for your help...
Message 1 of 1
(3,154 Views)
