LabVIEW Interface for Arduino Discussions
Labview Interaface of Arduino using Linx
I want to control stepper motor using Arduino through Labview LINX. As I am a beginner can anyone helps me out for this. I am using motor driver circuit ULN2003 with my Arduino Uno and my motor perfectly works with Arduino IDE code but I want the same with Labview. I am using Pin A2 as a analog i/p from Potentiometer and 10,11,12,13 as a digital o/p from Arduino, which goes to input 1,2,3 and 4 to the motor driver and then my motor runs. I am confused like do i require 4 digital write block in Linx or do i require PWM block for configuring this setup in Labview? or how can i enable this o/p pins from Labview ?
Right now I am only able to figure out my analog voltage by changing the potentiometer in Labview. The other part I don't know. Please, anyone guide me how to do it.
Thanks and I really appreciate your feedback.
Daxesh
Message 1 of 1
(2,975 Views)
