LabVIEW Interface for Arduino Discussions
How to read HMC 5883 Magnetometer
Hello Nathan,
Am trying to build a code to run on a SbRIO and collect data from a module (GY87) having a MPU6050 + HMC5883L + BMP180  and I need to collect data from them over I2C.
However all the codes I have seen online so far use LIFA and Arduino to pipeline the data over to the pc.
Can you help me on implementing the same on the RTOS of an SbRIO.?
Any input will be appreciated..
Regards.
Regards.
Digant Shetty (LV 18.0)
AE, Combined Digilog Systems Pvt. Ltd.
Message 21 of 24
(2,552 Views)
hi mehr im using hmc 5883l i used the library which nathan provided i got error 5003 in i2c read please help me out with this
Message 22 of 24
(2,404 Views)
i too got the same error 5003 in i2c read... did you find out how to get over it ???. did you get the output
Message 23 of 24
(2,404 Views)
@Nathan_B. wrote:
Here ya go.
i used this library to get output from hmc5883 using labview i get error 5003 at i2c read. i don't know why can you please help me out with this???..please
Message 24 of 24
(2,403 Views)
